Dynamic URL to image in List widget
9064
11
05-25-2021 09:55 AM
VHolubec
Hello,
in ExB I have a list widget which uses a data from table layer.
I need to set a image for each item in a list based on combination of fix url, and the attribute of the feature - which changes in time. Is there a way to do so?
It seems, that Arcade expressions are not supported / even it would be a best option there - to use something like:
"https://server.domain.com/images/" + {attribute} + ".png"
On a list I see for the image url just an attribute and function - none of them does not handle the example above.
Have someone know if there is any other way I missed?
Thank you.
Vladimir
Vladimir
BrunoSousa1
Hi @VHolubec
This is an expression that's working for me on the Beirut Recovery App:
Do you mind sharing a URL to an image in your table? I'm curious as why it's not working
BrunoSousa1
Hi
Not sure if you're doing this but your expression should look like: "https://server.domain.com/images/"+{attribute}+".png"
You can also have the whole URL as an attribute in the table, so you would only need to use the attribute instead of an expression if that's not working for you.
You can see this working on my apps:
Beirut Recovery Map
Perseverance Rover
VHolubec
Hi @BrunoSousa1
you are right, I just forgot the + marks there, but yes, with + marks it works fine in Arcade (I fixed this in original post).
Anyway, the static url attribute is not the option I am seeking for.
The attribute is related to state of water quality, and {attribute} can change quite often during the time (the values coming from domain), and the url attribute would be a one more attribute to maintain, which can raise more errors in data - anyway if there wouldn´t be any other change this is the last possible workaround.
Vladimir
P.S. very nice apps! Thank you for links.
Vladimir
BrunoSousa1
Hi @VHolubec
VHolubec
Hi, @BrunoSousa1,
it's awkward, I am sorry. I had there a wrongly quotation marks. The screenshot has helped me a lot.
Thank you so much!
Vladimir
Vladimir
by Anonymous User
Not applicable
Hi all,
I have a similar issue in where ArcGIS Experience does not fetch the image of an url I added in the data in a List Widget, see image below.
I tried replacing 'https' to 'http', but this did not help either. It is not a link that is made with an expression. (i.e. this image ).
So, it is not the exact problem as asked above, but a very similar one I guess. Could somebody steer me in the right direction or do you perhaps know it @BrunoSousa1 ?
Thanks!
Geert
BrunoSousa1
HI @Anonymous User ,
I added the URL of the image you mentioned to a table and tried it on a list widget and the imaged loaded.
You have the full image URLs within your table, right? They should work right away when you connect the List widget to the data/layer and choose the column/attribute that stores the full URL for each image.
Try again with the Chrome Developer Tools (F12) open on Console to see what error messages it shows.
by Anonymous User
Not applicable
Hi @BrunoSousa1
I tested it with a different layer file and saw I used the wrong column this whole time!! I appreciate your time in answering my question!
TravisLathrop_topeka
I've got a similar issue calling to an image from the list widget.
We have a working app that provides an image based on a 'RefID' field in our dataset.  This works fine in a pop up created in WebAppBuilder.  Our hyperlink is configured below....where the QuickRefID is a field that seaks to individual images.
https://ares.sncoapps.us/common/getphoto?quickref={QuickRefID}&size=large
That same statement doesn't seem to work in ExB.  Below is how I have the dialogue configured.
Anyone have any ideas whey this is not working as expected?
BrunoSousa1
Hi Travis,
Try this URL instead: "https://ares.sncoapps.us/common/getphoto?quickref="+{QuickRefID}+"&size=large"
Your expression is treating {QuickRefID} as a string part of the final URL, instead of dynamic data from a column. What I did was to separate the URL into 3 parts, concatenated with the column in the Middle.
You might have to add the column to that position by selecting it from the list of fields below the Expression area, as just typing it might not work.
Let me know if this helps.
