Dynamic text for web map properties
1119
07-11-2022 10:52 PM
JasonMinogue
Hi all,
I'm attempting to create some dynamic text to link to the properties of a web map in my experience (i.e. spatial reference).
In Pro I'd achieve this using the dynamic text tag with:
<dyn type="mapFrame" name="MapFrameName" property="sr" srProperty="name"/>
Which would return: WGS 1984 UTM Zone 56S (for example)
In the ExB text widget I can only find the functionality for pulling attributes from a layer, is there a way to include the map properties in a text widget, or is there a way using the embed widget?
TonghuiMing
@JasonMinogue Unfortunately, we have not provided any functions like that.
DanCopKac
What about at least adding the web map name to a text widget? I would like to add the version number of the web map (which is usually in the description, but i can also add it to the web map name).
Whenever I make updates to the web map and add a new version number, it would be ideal if I didn't have to also get a production change approval just to redeploy my Experience app to update the text widget manually with the web map's version number being referenced.
