Download Experience Bldr App created in AGO
2105
05-12-2021 02:09 PM
NataliyaLys
I have created an Exp Builder application in the AGO. I would like to download the application and deploy it on my web server.
I don't see an easy way to just download the app. So I have done the following steps:
  1. I created a template from by ExpBlrd application in AGO
  2. Then in ExpBldr Dev Edition I created an new application (Experience) from the template created in step 1
  3. All of the above steps worked fine. But when I opened my new application in the ExpBldr Dev Edition, I got an error 'Cannot read property 'widgetType' of undefined'
    1. It looks like the problem is happening because I am using the 'Query Widget' in  my application - and it looks like it might not be available in Dev Edition.
Is there any other ways to download the app, or does anyone has any other suggestions?
Nataliya
DavidMartinez
Hi Nataliya,
Currently, that is the easiest way. We are releasing the 1.4  dev edition today and you should not have this error if you use this version.
Cheers,
David
BrunoSousa1
Hi David, I am getting the same Error Message on 1.4 when I add a Views Navigation Widget within a Sections Widget. This works fine on 1.3. Should I ask this on a new Post?
DavidMartinez
Hi Bruno,
Yes, let's ask this in a new post so some of my colleagues can see what the issue is.
Cheers,
David
