Display Resolution Issues: Map Image Layers BREAKS on larger display
3547
07-22-2021 12:15 AM
RYANCARL
Hello all,
I am really hoping there is a good solution to this.
I am having screen size / resolution issues with Map Image Layers that are associated with my experience. When the computer screen is in the 1920 X 1080 resolution everything works perfectly, but when I switch to 2560 X 1440 the Map Image Layer is completely broken.
This image is the screen resolution at 1920 X 1080:
Screen Shot 2021-07-22 at 12.03.08 AM.pngScreen Shot 2021-07-22 at 12.03.08 AM.png
As you can see this is working perfectly.
This image is the screen resolution at 2560 X 1440:
Screen Shot 2021-07-22 at 12.12.46 AM.pngScreen Shot 2021-07-22 at 12.12.46 AM.png
As you can see something is very wrong here.
Any help or insight with this issue is very appreciated.
EDIT: This issue is effecting only 2D maps.
JonathanMcDougall
@RYANCARL
Hi, I've added a couple of  image layers to a 2d map and have tried to replicate this, but have not been able to.
As I build experiences I use a plugin for Chrome/Edge called Windows Resizer to make sure I keep things usable for a 1080, 1050, or 900 user as I work off 1440p.
In this case I've used the plugin as well as changing my screen res to the lower 1080, 1050, and 900 - no joy. I'm going to surmise that your issue is browser redraw and cache based more than ExpB or the map widget as you've got a lot of information in that layer - I think it's just taking a long time for your browser to update.
Are you able to share the map, even if it's just fired into a simple ExpB so we can try to replicate?
NicolasGIS
Honored Contributor
Faced the same issue.
It can be fixed by increasing the Maximum Image Height and Width in pixels at the Map Service level:
The fact that it is shifted in the JS API is due to the fact that it asks for an image size that satisfies these limit s though it does not cover the full screen once generated.
Phenomena observed using ESRI Maps SDK for javascript 4.27.
