Disabling Sign In Popup
4949
10
12-23-2022 11:00 AM
MarkEastwood
Hi All,
When opening an experience we are getting a popup widow asking us to sign in to ArcGIS Online. Clicking "Okay" then opens up the panel where we can enter in our credentials but we would like to bypass the initial popup.
In Web AppBuilder, we were able to disable the initial sign in panel by editing the ./jimu.js/tokenUtils.js file. On line 17 of the code snippet below, setting the popup parameter to false hides the sign in popup. Is there something similar in the Experience Builder code?
registerOAuthInfo: function(portalUrl, appId){
      var validParams = portalUrl && typeof portalUrl === 'string' &&
       appId && typeof appId === 'string';
      if(!validParams){
        return null;
      var oAuthInfo = esriNS.id.findOAuthInfo(portalUrl);
      if(!oAuthInfo){
        var oauthReturnUrl = window.location.protocol + "//" + window.location.host +
         require.toUrl("jimu") + "/oauth-callback.html";
        //OAuth will lose 'persist' query parameter if set expiration to two weeks exectly.
        oAuthInfo = new OAuthInfo({
          appId: appId,
          expiration: 14 * 24 * 60 - 1,
          portalUrl: portalUrl,
          authNamespace: '/',
          popup: false,
          popupCallbackUrl: oauthReturnUrl
        esriNS.id.registerOAuthInfos([oAuthInfo]);
      oAuthInfo.appId = appId;
      return oAuthInfo;
BrandonWebb
Yes as @RajatBatham said, modify the jimu-arcgis/index.js in the deployed application.  You can search the file for popup:!0 and replace with popup:false.  You must clear your browser cache to see results.
KamilNovák
I don't have a solution but I would also like to know if there is a solution.
Thanks.
mohannainar1
Hi @MarkEastwood  did you find the solution ?. If so can you please tell me how to disable the login popup. I too facing the same issue
JonNordling3
Any solution on this?
RajatBatham
The same method you will be able to find in jimu-arcgis/index.js and then just do the same as we did in Web App builder
BrandonWebb
AllenovDmitriy
There is no popup:!0 in jimu-arcgis/index.js file in version 1.17
RajatBatham
with 1.17 version, ESRI have moved this method to jimu-core/index.js.
search for popup:!0 and replace it with popup:!1.
AllenovDmitriy
Now I have to login with full window interface ☹️
How to disable login procedure in ExB application, if I have already logged into the portal on the adjacent tab?
NHannig
Editing a source file seems like a poor solution prone to overwrite.
It needs to be a option/setting in Experience Builder.
