Add a button with conditinal visability - activated by layers
777
06-19-2025 08:57 AM
WFCAdmin
I am producing a map with numerous layers.
Each layer represents the results of a model. A brief description of the model, to help end users understand what they are viewing, is available at different URLs.
I would like a button to appear in the lower left-hand corner of the map when certain layers are turned on. This button would provide a clickable link to the URL describing the model that generated the active layer.
Is this possible?
Thank you!
Ke_Xu
by Esri Regular Contributor
Hi @WFCAdmin,
When 2 layers are visible, will there be 2 Links in the Button?
Ke
WFCAdmin
Yes,
If possible!
Thank you.
Aaron
