Disable service layer attribution in Experience Builder?
2024
06-04-2024 03:00 AM
xingchenc
Hi community,
After adding a map widget, is there an easy way to remove the service layer attribution at the bottom of the map? Please see the screenshot below.
I found this solution ( https://community.esri.com/t5/arcgis-web-appbuilder-questions/is-there-anyway-to-turn-off-service-la... ) but it seems not working for experience builder?
Please help!
JeffreyThompson2
MVP Frequent Contributor
https://developers.arcgis.com/faq/#licensing-required-attribution
It is virtually impossible to remove the Attribution without violating the Terms of Service.
GIS Developer
City of Arlington, Texas
xingchenc
I understand it's necessary for the scenario mentioned above, but if i'm using my own data, there should be an option to block this message from showing up.
JeffreyThompson2
You are using an Esri basemap. That is what is generating the attribution line.
GIS Developer
xingchenc
Still looking for solutions.
