Default value if value = null
4058
6
09-14-2022 08:38 AM
DavidRasner1
Hello,
I was wondering if anyone maybe knows how to format a dynamic text value (attribute) with a default value if empty. I would prefer to do it via UI, not in the DB.
Something like:
If missing then "Missing value"
else {Attribute}
I couldn't find any info on this.
DanJiang
Hi @DavidRasner1 ,
You can use the Expression instead of the Attribute in Dynamic content. Set the expression name as the default value you want and configure the expression content as the attribute.
DanJiang
Hi @DavidRasner1 ,
HowieBrown
This is way past awesome ... I have searched everywhere for this and where to do it. I need this because the First_and_Last_Name field is not mandatory in the survey, but I need the field to have Anonymous in it if they leave it blank - - - The Data base that imports the results can not be null.. Setting it up as a Default would cause problems on the end ...
Anyway - Thank You So Much !!!!!
DavidRasner1
Ah, thanks!
apgis16
I tried to do this with a date field I have within a list. I want it to display "Pending" If it's NULL. The populated dates show up but the empty ones still don't show anything. Does this not work on a date field?
LindsayWithers1
I'm having the same problem, but on a numeric field. Did you ever get the Expression name to work for null values on your date field?
apgis16
No 😞
