Copy Features Function Missing from Experience Builder Edit Widget
9172
33
09-19-2023 08:55 AM
JeremyBrown4
I have been searching the community site for a while looking for an answer to this question, but every time I see it asked there is no response from ESRI. I will go ahead and @AlixVezina , since she wrote the last article I read on the new Edit widget in ExB.
My question is, are there any plans to updated the new Edit widget in ExB to include the Copy Features functionality that the WAB version currently has? If not, will there be some combination of features or Arcade functionality to accomplish this task, or will it simply be unavailable in ExB?
JasonFitzsimmons
HI @AlixVezina, thanks for the quick reply.
I am trying out the Survey widget you mentioned, described here:
https://www.esri.com/arcgis-blog/products/experience-builder/real-time/using-experience-builder-and-...
My initial tests are promising,  but I am very new to Survey123.
So far I can select geometry and attributes  and pass them into another layer using Survey with 'send data to this survey' enabled and setting connections, but the new feature  does not appear in the target layer in Experience after I save the edit.
When I then view the related Web Map, I can see the edits, and if I refresh the Experience page, I can then see them. Am I missing something obvious?
Thanks, Jason
AlixVezina
@JasonFitzsimmons , I checked with the team and it looks like this is a known issue in progress of being fixed. It may not make it to the upcoming release, but it should be resolved in the next one.
Perhaps for now, a workaround could be to provide a Button widget to "refresh" the app? The user could hit that button if they want to easily refresh the app and see their changes.
JasonFitzsimmons
hi @AlixVezina , thanks for the info and suggestion, I'll look into that .
However, the fact that only one feature can be selected and added to a different layer using Survey won't work for us. We need to select multiple street segments, which will be added as a stretch in the target layer.
Andrus_Nicholas
Attempting to build workflows that empower my users to own their own data and not rely on power users for editing.  Need this functionality!
