Coordinate Conversion cant rename label
1264
10-17-2023 09:09 AM
abureaux
MVP Frequent Contributor
I am curious how this even happened.
I am looking to edit some things in Coordinate Conversion and want to rename something. Thankfully I can edit the Lat-Long output (X°‎, Y°‎ > Y, X). But why can't I edit the label?? It stays as the default of "Long-Lat":
But it's not like they don't know people would want to edit the label since the End User can:
But there is more... The End User gets a "reset" button. And when you press it... It only resets the "Format" while completely ignoring the "Label" field!
Am I missing something here, or is this actually how this works?
Also, zoom doesn't seem to work at all? I set a zoom of 1:5 and nothing happens. Edit: I guess the only way to zoom is by pressing the button. There should be a toggle or something to do that automatically as well.
DavidDas__GISP
You can change the Labels in the Coordinate Conversion Widget in the Developer Edition of the Experience Builder.
Here is an example:
Before
DD
DMS
After
Decimal Degrees
Degree Minute Seconds
To do this, you must edit the config.json files.
There are two config.json files
Server/public/apps/app-id/config.json
Server/public/apps/app-id/resources/config/config.json
   "widget_29": {
      "uri": "widgets/arcgis/coordinate-conversion/",
      "version": "1.12.0",
      "label": "Coordinate Conversion",
      "config": {
        "inputSettings": {
          "defaultCoordinate": "xy",
          "format": "X°‎, Y°‎"
        "outputSettings": [
            "name": "address",
            "label": "Address",
            "defaultPattern": "",
            "currentPattern": "",
            "enabled": true,
            "isCustom": false
            "name": "dd",
            "label": "Decimal Degrees",
            "defaultPattern": "Y°‎N, X°‎E",
            "currentPattern": "X°‎E, Y°‎N",
            "enabled": true,
            "isCustom": false
            "name": "dms",
            "label": "Degree Minute Seconds",
            "defaultPattern": "Y°‎ A' B\"N, X°‎ C' D\"E",
            "currentPattern": " X°‎ C' D\"E, Y°‎ A' B\"N",
            "enabled": true,
            "isCustom": false
You can change the Zoom Scale here as well.
In this example the Zoom Scale is set to 1:2000
        "addressSettings": {
          "minCandidateScore": 100,
          "maxSuggestions": 6,
          "useUtilitiesGeocodeService": [
              "utilityId": "utility_1"
          "geocodeServiceUrl": "https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"
        "generalSettings": {
          "zoomScale": 2000,
          "defaultPointSymbol": {
            "type": "esriPMS",
            "angle": 0,
            "xoffset": 0,
            "yoffset": 0,
DavidDas__GISP
Here is an example:
Before
DD
DMS
After
Decimal Degrees
   "widget_29": {
      "config": {
        "inputSettings": {
        "outputSettings": [
            "name": "address",
            "label": "Address",
            "enabled": true,
            "isCustom": false
            "name": "dd",
            "enabled": true,
            "isCustom": false
            "name": "dms",
            "enabled": true,
            "isCustom": false
          "zoomScale": 2000,
            "type": "esriPMS",
            "angle": 0,
            "xoffset": 0,
            "yoffset": 0,
pandyahariom001
How can we change label for ADDRESS .
can anyone please help
