I am curious how this even happened.
I am looking to edit some things in Coordinate Conversion and want to rename something. Thankfully I can edit the Lat-Long output (X°, Y° > Y, X). But why can't I edit the label?? It stays as the default of "Long-Lat":
But it's not like they don't know people would want to edit the label since the End User can:
But there is more... The End User gets a "reset" button. And when you press it... It only resets the "Format" while completely ignoring the "Label" field!
Am I missing something here, or is this actually how this works?
Also, zoom doesn't seem to work at all? I set a zoom of 1:5 and nothing happens. Edit: I guess the only way to zoom is by pressing the button. There should be a toggle or something to do that automatically as well.
You can change the Labels in the Coordinate Conversion Widget in the Developer Edition of the Experience Builder.
Here is an example:
Before
DD
DMS
After
Decimal Degrees
Degree Minute Seconds
To do this, you must edit the config.json files.
There are two config.json files
Server/public/apps/app-id/config.json
Server/public/apps/app-id/resources/config/config.json
"widget_29": {
"uri": "widgets/arcgis/coordinate-conversion/",
"version": "1.12.0",
"label": "Coordinate Conversion",
"config": {
"inputSettings": {
"defaultCoordinate": "xy",
"format": "X°, Y°"
"outputSettings": [
"name": "address",
"label": "Address",
"defaultPattern": "",
"currentPattern": "",
"enabled": true,
"isCustom": false
"name": "dd",
"label": "Decimal Degrees",
"defaultPattern": "Y°N, X°E",
"currentPattern": "X°E, Y°N",
"enabled": true,
"isCustom": false
"name": "dms",
"label": "Degree Minute Seconds",
"defaultPattern": "Y° A' B\"N, X° C' D\"E",
"currentPattern": " X° C' D\"E, Y° A' B\"N",
"enabled": true,
"isCustom": false
You can change the Zoom Scale here as well.
In this example the Zoom Scale is set to 1:2000
"addressSettings": {
"minCandidateScore": 100,
"maxSuggestions": 6,
"useUtilitiesGeocodeService": [
"utilityId": "utility_1"
"geocodeServiceUrl": "https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"
"generalSettings": {
"zoomScale": 2000,
"defaultPointSymbol": {
"type": "esriPMS",
"angle": 0,
"xoffset": 0,
"yoffset": 0,
Here is an example:
Before
DD
DMS
After
Decimal Degrees
"widget_29": {
"config": {
"inputSettings": {
"format": "X°, Y°"
"outputSettings": [
"name": "address",
"label": "Address",
"enabled": true,
"isCustom": false
"name": "dd",
"enabled": true,
"isCustom": false
"name": "dms",
"enabled": true,
"isCustom": false
"zoomScale": 2000,
"type": "esriPMS",
"angle": 0,
"xoffset": 0,
"yoffset": 0,
How can we change label for ADDRESS .
can anyone please help
