change the colore of the selection
2254
11-21-2021 05:39 AM
giladuzann
hallow.
I want to change the color of the choice from turquoise to another color.
When I choose a particular polygon, the choice is turquoise but I want it to be a different color.
Is this even possible?
thanks
DanPatterson
MVP Esteemed Contributor
is it a map widget?
Map widget—ArcGIS Experience Builder | Documentation
Options
Selection highlight—Change the highlight color for features selected in the map.
... sort of retired...
TonghuiMing
@giladuzann @DanPatterson - This issue should have been fixed and the selection change will take effect. Could you please double-check? Thanks.
FredericPoliart_EsriAU
1. Clone the entire 'arcgis-map' folder from ArcGISExperienceBuilder\client\dist\widgets\arcgis\arcgis-map
2. paste it in your \ArcGISExperienceBuilder\client\your-extensions\widgets  but rename the folder
to \my-arcgis-map\
3. Edit your manifest.json  ( "name": "my-arcgis-map", ) < must be exactly the same name as the folder name.
4. Add your my-arcgis-map widget in your project instead of the original (+select an AGOL map)
5. Edit the file \ArcGISExperienceBuilder\client\your-extensions\widgets\bcc-arcgis-map\src\runtime\components\mapbase.tsx   (not basemap.tsx, there is also a basemap.tsx but don't change that one)
6. Locate   if (config.selectionHighlightColor) {
7. add your own code in there: (there is a haloColor and HaloOpacity but it doesn't seem to work yet)
      // this.mapView.highlightOptions.color = new this.Color(config.selectionHighlightColor);
      this.mapView.highlightOptions.fillOpacity = 0.0;
      this.mapView.highlightOptions.haloOpacity = 0.95;
      this.mapView.highlightOptions.color = new this.Color('#00FF00');
      this.mapView.highlightOptions.haloColor = new this.Color('#FF0000');
      console.log('----------use Chrome Console to look at Object this.mapView.highlightOptions')
      console.log(this.mapView.highlightOptions)
8. Reload the map
voilà .
Ideally I would love to be able to create my own renderer and create some fancy double-lines,  dashed red and white with a proper halo,  but unfortunately it is a bit limited for now.
=F=
@giladuzann wrote:
hallow.
thanks
