Change edit popup title
1784
05-30-2024 12:25 PM
CambriaEwart
I have an edit widget but would like to change the title of it. Below I have attached an image circling what I want to change. Thanks!
marksm_macomb
In experience builder, first click on the edit widget to bring up its properties pane, then you should be able to just click the title and type whatever you want here:
CambriaEwart
Thank you! I was also wondering if there was a way to change the 33 to a different title.
Laura
by MVP Regular Contributor
This should get you what you're looking for: https://community.esri.com/t5/arcgis-online-questions/change-default-field-displayed-in-map-viewer-e...
I have had the same issue. Wish it could be done in an easier way.
