Card widget flashes the first time the user hovers over it
1349
08-04-2022 08:13 AM
SophiaUthe
Hello!
I'm using empty-template card widgets in my EB that I want users to be able to hover over and then click to go to the URL link. The problem is that the first time the user hovers over it, it "flashes" once and then it works fine. I've made sure that all animation/transition settings are turned off, both regular and hover card positions are set to fit, and the card contents are the exact same for regular and hover mode if that's useful.
Am I missing something or is this a bug? I'm pretty new to this so I'd be very happy if there's an easy fix!! I attached an example video of what's happening.
Thank you,
Sophie
https://youtu.be/i1fB6RreRYg
Wei_Ying
Hi Sophie,
Thanks for your feedback. Looks like it is a bug, and we will try to fix.
Wei
Wei_Ying
Hi Sophie,
Wei
JohannesPetrone
Any updates on this @Wei_Ying ? This bug is still present in Enterprise 11.5 and makes the hover unusable when dealing with images in cards. I am guessing the card widget has lazy loading and doesnt load the hover image until the user hovers over the card?
Wei_Ying
This should be fixed in latest online edition, but for Enterprise it would be 12.1, unless you request a hotfix for 11.5
