Card widget flashes the first time the user hovers over it
299
08-04-2022 08:13 AM
SophiaUthe
New Contributor II
Hello!
I'm using empty-template card widgets in my EB that I want users to be able to hover over and then click to go to the URL link. The problem is that the first time the user hovers over it, it "flashes" once and then it works fine. I've made sure that all animation/transition settings are turned off, both regular and hover card positions are set to fit, and the card contents are the exact same for regular and hover mode if that's useful.
Am I missing something or is this a bug? I'm pretty new to this so I'd be very happy if there's an easy fix!! I attached an example video of what's happening.
Thank you,
Sophie
https://youtu.be/i1fB6RreRYg
WeiYing1
Hi Sophie,
Thanks for your feedback. Looks like it is a bug, and we will try to fix.
Wei
WeiYing1
Hi Sophie,
Wei
