Business Analyst tool - how to select data within buffer??
1923
6
02-05-2025 05:47 PM
Hels77
Hi, I am trying to find a solution using the Business Analyst tool in EB, not sure its the right fix though.
I want the user to be able to set a buffer by drive time (this works well) but I also want to be able to select all data that falls within that buffer and display in a table (and export/ add data).
Is there a way to do this?
Thanks!
Hels77
Solved by creating buffers in ArcGIS online with the Bussiness Analyst tool and then using the select location tool in ArcGIS Pro.
JasonBOCQUET
Hi @Hels77 you can add a table on your Report Template and made an export of this table to an excel file by clicking on the left icons as you can see on my screenshot below
Hels77
Thanks, Jason. The table doesn't pick up the buffer zones created by the Analyst tool, or at least I haven't been able to make it do it. And drawing around the complex shapes it creates is not doable. But yes, I want to be able to export from the table if possible.
JasonBOCQUET
On Experience Builder you have a Business Analyst Widget to do that.
you can search with an adress, place a pin or draw a polygon on the Map Widget.
Next step,
you create your buffer, it can be a travel time zone, walking time zone or circle.
And by using this area zone, you can generate your report with a table in the template.
Hels77
Jason, what do you mean by 'generate your report with a table in the template'?
JasonBOCQUET
in my original post i show to you one of my template :
There is a table in this template
Hels77
