Hi, I am trying to find a solution using the Business Analyst tool in EB, not sure its the right fix though.
I want the user to be able to set a buffer by drive time (this works well) but I also want to be able to select all data that falls within that buffer and display in a table (and export/ add data).
Is there a way to do this?
Thanks!
Solved by creating buffers in ArcGIS online with the Bussiness Analyst tool and then using the select location tool in ArcGIS Pro.
Hi @Hels77 you can add a table on your Report Template and made an export of this table to an excel file by clicking on the left icons as you can see on my screenshot below
On Experience Builder you have a Business Analyst Widget to do that.
you can search with an adress, place a pin or draw a polygon on the Map Widget.
Next step,
you create your buffer, it can be a travel time zone, walking time zone or circle.
And by using this area zone, you can generate your report with a table in the template.
Jason, what do you mean by 'generate your report with a table in the template'?
in my original post i show to you one of my template :
There is a table in this template
