Arcade: MapViewer pop-ups not loading in field values if field is referenced using a variable - browser loading issue?
373
2 weeks ago
TaraHaynes
UPDATE:
I have determined that my original assumptions that functions were causing this issue was incorrect. I have added updated info at the bottom of the post.
Original:
On the left-hand side is the pop-up in the Map Widget. On the right-hand side is the Feature Info widget, showing the pop-up as expected. All of the missing data/styling on the map widget pop-up was generated by functions within Arcade (in the pop-up in MapViewer), which is why I suspect them to be the culprit.
Here is an example of one of my functions:
function label (status) {
	if (status == "No Survey Data") {
		return "Not Surveyed"
	else if (status == "No Nest Assessment Data") {
	else if (status == "NA") {
		return "N/A"
	else if (Find("Unknown",status,0) > 0) {
		return "Unknown"
	else {
		return status
Here is how I am bringing these values into the HTML:
var nest_row=`<tr><td style="padding:2px;"><b>${yr}</b></td><td style="padding:3px;border-left:5px solid ${bgcolor($feature[nestfield_name])}"><i>Discovered</i> - ${label($feature[nestfield_name])}</td><td style="padding:3px;border-left:5px solid ${bgcolor($feature[occfield_name])}">${label($feature[occfield_name])}</td></tr>`
Update:
When I reference a field using a variable, as below, the value will not show up in the MapViewer pop-up:
var fldname = "NestStatus_2016"
return $feature[nestfield_name]
if the field name is called directly, as below, the value appears in the pop-up:
return $feature.NestStatus_2016
If I reference the field directly at all in the script, even as a variable that doesn't get used, it will then show up in the pop-up where $feature[nestfield_name] is used. Which is to say that I have a workaround and my pop-up is functional, but I have to list every field I want to reference so that it can show up (this is a simplified version of what my script is doing):
// referencing list of fields i need directly
var flds = [$feature.NestStatus_2024,$feature.NestStatus_2025,$feature.NestStatus_2026]
// calculating # of years between today and the year of nest detection
var yrs = Year(Now()) - $feature.Year_Detected
year_range = Array(yrs)
tbl_rows = ``
for (n in array) {
  yr = $feature.Year_Detected+n
  fld = `NestStatus_${yr}`
  tbl_rows = `<tr><td>yr</td><td>$feature[fld]</td></tr>`+tbl_rows
return tbl_rows
I know that 'year' fields are not great data management, and I hope to improve that in the future, but I suppose this is what I'm dealing with for now. Either way, this seems like it could be some kind of bug related to how the browser is loading pop-ups... interested to know if anyone else has run into this.
ZachBodenner
MVP Regular Contributor
I can't imagine why this would be the case based solely on your provided code, but I notice that you do have at least one variable (bgcolor) you haven't shown so I suppose I'll ask: Are you sure they're not showing up? Might they be white text on white background somehow? There's a setting in the feature info widget that can override some popup arcade, so perhaps it's doing that which is why it looks black in the feature info widget?
Happy mapping,
- Zach
TaraHaynes
There is no text at all, I did double-check whether it had turned white. To that end, there is other text in the pop-up (not generated by functions) which appears as expected in the Map Widget pop-up and is black. I have my 'Theme' text in ExperienceBuilder set to black.
Bgcolor changes the colour to the left of the Status and Occupancy value - you'll notice that it's all grey in the left-hand pop-up (Map Widget), while yellow is appearing properly in the right-hand pop-up (Feature Info Widget), which indicates that that function isn't working either in the Map Widget pop-up.
For posterity, here is the bgcolor function:
function bgcolor (status) {
	if (status == "NA" || status == "No Survey Data" || status == "No Nest Assessment Data") {
		return `#e3e3e3`
	else if (status == "Not Detected" || status == "Inactive" || status == "Destroyed") {
		return `#FFD899`
	else if (status == "Resident" || status == "Breeding" || status == "Active") {
		return `#639C5F`
	else {
		return `#e3e3e3`
ZachBodenner
Are you willing/able to share maps and or data? I'd be curious to look at the whole thing and see if I can reproduce that error. If you are, feel free to send me a private message to coordinate that.
Happy mapping,
- Zach
