Arcade: MapViewer pop-ups not loading in field values if field is referenced using a variable - browser loading issue?
666
05-05-2026 01:31 PM
TaraHaynes
UPDATE:
I have determined that my original assumptions that functions were causing this issue was incorrect. I have added updated info at the bottom of the post.
Original:
On the left-hand side is the pop-up in the Map Widget. On the right-hand side is the Feature Info widget, showing the pop-up as expected. All of the missing data/styling on the map widget pop-up was generated by functions within Arcade (in the pop-up in MapViewer), which is why I suspect them to be the culprit.
Here is an example of one of my functions:
function label (status) {
	if (status == "No Survey Data") {
		return "Not Surveyed"
	else if (status == "No Nest Assessment Data") {
	else if (status == "NA") {
		return "N/A"
	else if (Find("Unknown",status,0) > 0) {
		return "Unknown"
	else {
		return status
Here is how I am bringing these values into the HTML:
var nest_row=`<tr><td style="padding:2px;"><b>${yr}</b></td><td style="padding:3px;border-left:5px solid ${bgcolor($feature[nestfield_name])}"><i>Discovered</i> - ${label($feature[nestfield_name])}</td><td style="padding:3px;border-left:5px solid ${bgcolor($feature[occfield_name])}">${label($feature[occfield_name])}</td></tr>`
Update:
When I reference a field using a variable, as below, the value will not show up in the MapViewer pop-up:
var fldname = "NestStatus_2016"
return $feature[nestfield_name]
if the field name is called directly, as below, the value appears in the pop-up:
return $feature.NestStatus_2016
If I reference the field directly at all in the script, even as a variable that doesn't get used, it will then show up in the pop-up where $feature[nestfield_name] is used. Which is to say that I have a workaround and my pop-up is functional, but I have to list every field I want to reference so that it can show up (this is a simplified version of what my script is doing):
// referencing list of fields i need directly
var flds = [$feature.NestStatus_2024,$feature.NestStatus_2025,$feature.NestStatus_2026]
// calculating # of years between today and the year of nest detection
var yrs = Year(Now()) - $feature.Year_Detected
year_range = Array(yrs)
tbl_rows = ``
for (n in array) {
  yr = $feature.Year_Detected+n
  fld = `NestStatus_${yr}`
  tbl_rows = `<tr><td>yr</td><td>$feature[fld]</td></tr>`+tbl_rows
return tbl_rows
I know that 'year' fields are not great data management, and I hope to improve that in the future, but I suppose this is what I'm dealing with for now. Either way, this seems like it could be some kind of bug related to how the browser is loading pop-ups... interested to know if anyone else has run into this.
ZachBodenner
MVP Regular Contributor
I can't imagine why this would be the case based solely on your provided code, but I notice that you do have at least one variable (bgcolor) you haven't shown so I suppose I'll ask: Are you sure they're not showing up? Might they be white text on white background somehow? There's a setting in the feature info widget that can override some popup arcade, so perhaps it's doing that which is why it looks black in the feature info widget?
Happy mapping,
- Zach
TaraHaynes
There is no text at all, I did double-check whether it had turned white. To that end, there is other text in the pop-up (not generated by functions) which appears as expected in the Map Widget pop-up and is black. I have my 'Theme' text in ExperienceBuilder set to black.
Bgcolor changes the colour to the left of the Status and Occupancy value - you'll notice that it's all grey in the left-hand pop-up (Map Widget), while yellow is appearing properly in the right-hand pop-up (Feature Info Widget), which indicates that that function isn't working either in the Map Widget pop-up.
For posterity, here is the bgcolor function:
function bgcolor (status) {
	if (status == "NA" || status == "No Survey Data" || status == "No Nest Assessment Data") {
		return `#e3e3e3`
	else if (status == "Not Detected" || status == "Inactive" || status == "Destroyed") {
		return `#FFD899`
	else if (status == "Resident" || status == "Breeding" || status == "Active") {
		return `#639C5F`
	else {
		return `#e3e3e3`
ZachBodenner
Are you willing/able to share maps and or data? I'd be curious to look at the whole thing and see if I can reproduce that error. If you are, feel free to send me a private message to coordinate that.
Happy mapping,
- Zach
Ke_Xu
by Esri Regular Contributor
Hi @TaraHaynes ,
I noticed you mentioned that the popup is also not displaying correctly in Map Viewer. Experience Builder popups also use components from the ArcGIS Maps SDK for JavaScript, so the behavior is consistent with Map Viewer.
With the June 2026 ArcGIS Online update for ArcGIS Experience Builder, popups have been migrated to web components. Can this issue still be reproduced?
If so, I suggest submitting this issue to Esri Support so it can be routed to the ArcGIS Maps SDK for JavaScript team.
Ke
