Adding a FeatureLayer that can be used in select/table
1599
09-16-2024 08:59 AM
jwilner_amica
I am trying to add a FeatureLayer to my map. It adds visually, and to Layer list, but cannot be added to the attribute table, or used in select widget, etc. I assume it is an issue where it needs to be added as a data source, but I haven't been able to figure that out. Any help would be appreciated!
const data: DataSourceJson = {
                  id: 'Hail Swath ' + dt,
                  layerId: layer.id,
                  type: DataSourceTypes.FeatureLayer,
                  geometryType: layer["geometryType"],
                  label: layer.title
                const dataJson = Immutable(data)
                const dataSourceOptions = {
                  layer: layer,
                  dataSourceJson: dataJson
                const something = dsManager.current.createDataSource(dataSourceOptions).then((dataSource: FeatureLayerDataSource) => {
                  map.current.view.dataSourceId = dataSource.id
                  map.current.view.map.add(dataSource.layer);
                }).catch((error) => {
                  console.error('Error creating DataSource:', error);
The layer is defined as such:
let layer = new FeatureLayer({
                  source: featureset,  // autocast as a Collection of new Graphic()
                  objectIdField: "OBJECTID",
                  geometryType: "polygon",
                  popupTemplate: template,
                  fields: swath.value.fields,
                  title: 'Hail Swath ' + dt,
                  opacity: 0.8
and uses a unique-value renderer
It adds to layer list:
but with limited functionality compared to other layers added through Add Data widget:
It also does not show up in the Add Data widget:
Thank you!
2 Solutions
JeffreyThompson2
MVP Frequent Contributor
There are two ways to add a FeatureLayer to Experience Builder. If you use the methods from the JavaScript API, the data will only be visually accessible. To get all of the data functionality, it must be transformed, added and recognized as an Experience Builder datasource.
This thread should help. https://community.esri.com/t5/arcgis-experience-builder-questions/making-runtime-featurelayers-regis...
GIS Developer
City of Arlington, Texas
jwilner_amica
JeffreyThompson2
GIS Developer
jwilner_amica
Thank you for the quick response, I'll give that a look!
jwilner_amica
Reference this solution, in my case the other worked, but had issues with renderer.
https://community.esri.com/t5/arcgis-experience-builder-questions/loss-of-renderer-with-runtime-crea...
