Action to Switch floors using Floor Filter Widget
1521
11-02-2023 11:30 AM
Andrew-Bowne
I have an ExB app built that shows a subset of Indoors Units in a List widget.  There is also a map widget that is configured as floor aware.   Ideally the workflow is to select an item in the list and have the map zoom to and filter the proper floor in order to display that unit on the map. I don't seem to see a way to be able to select an item from the List and have an action that changes the floor filter widget to the proper floor.
Does this functionality exist?  If not, does anyone have a workaround?
TonghuiMing
There is a support ticket to track - BUG-000159820.
TonghuiMing
Andrew-Bowne
Thank you!  I'll keep an eye on this.  Fixing this bug will solve a lot of headaches in our organization.  We have many many floor aware experience builder apps.
Is there any sort of timeline on a resolution?
DougFenske
I'm using Enterprise 11.5 and would like to have this functionality available, too. I would like to have the Floor Filter Widget active/open in an Experience and be able to then use the Search Widget to search for, and zoom to, a person on any floor in any building in our dataset. Currently the search results are limited to only the 1st floor of any building, or the currently selected floor in the Browse of the Floor Filter Widget.
