Action to Switch floors using Floor Filter Widget
527
11-02-2023 11:30 AM
AndrewBowne
I have an ExB app built that shows a subset of Indoors Units in a List widget.  There is also a map widget that is configured as floor aware.   Ideally the workflow is to select an item in the list and have the map zoom to and filter the proper floor in order to display that unit on the map. I don't seem to see a way to be able to select an item from the List and have an action that changes the floor filter widget to the proper floor.
Does this functionality exist?  If not, does anyone have a workaround?
TonghuiMing
There is a support ticket to track - BUG-000159820.
TonghuiMing
AndrewBowne
Thank you!  I'll keep an eye on this.  Fixing this bug will solve a lot of headaches in our organization.  We have many many floor aware experience builder apps.
Is there any sort of timeline on a resolution?
