Ability to duplicate/copy an element?
10242
14
03-04-2020 06:54 AM
BrianBaldwin
So far, Experience Builder has been great - but there is one enhancement that would help a lot.
Could we get the ability to duplicate elements?
In the example below I have configured the heights, spacing, backgrounds, etc. for the Column and child rows and I want to have the same settings for a column element below it. It would be a great feature if a user could simply 'select' a group of elements and then duplicate or copy it.
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
ShengdiZhang
Hi @ShariForbes ,
You can click the duplicate button on the widget toolbar to duplicate a widget on the same page.
If you want to copy and paste widgets across different pages in one experience, you can select the widget and press Ctrl+C, and then select the target page and press Ctrl+V to paste the widget.
Regards,
Shengdi
DavidMartinez
Hi Brian,
Absolutely, this is on our roadmap.
BrianBaldwin
Thanks so much for the quick reply David Martinez‌! Really looking forward to that feature.
FYI Patrick Huls
Dunn_Jeremy
Morning David
What's the best way to clone a web app from experience builder so that another user has ownership of it and all it's reference content ?
Regards.
Jeremy.
DavidMartinez
Hi Jeremy,
If the user is in your organization and you have admin rights you can change the ownership for each item under my content. Another option is to use the python api to use the reassign_to  method to change the other user.   I guess my question is are you looking just to clone or change ownership?  If change ownership you can do the above. If you need to clone there is a clone method in the python API. However, I noticed there are issues when the experience has images. The last time I used that method it had some issues with SVG. You could try that method and see if it works.
Cheers,
David
ShariForbes
Do you know if there has been any movement on this? I'd like to copy a perfectly beautiful row layout onto other pages.
ShengdiZhang
Hi @ShariForbes ,
Regards,
Shengdi
GarySchells
I'm copying and pasting list widgets on to different views in the same xperience.  However, each one needs a different filter.  when I set the filter one one of the lists, it keeps applying that filter to all the others.  Can anyone explain why this is happening and how I can get the correct filter on each list widget?
Thank you
hgdean
@ShengdiZhang I am having this issue as well. Is there a way to copy an element to a different view (i.e. desktop view to tablet view) and not have it retain a link to it's original version?
ShengdiZhang
I'm not sure I'm understanding the question correctly. If you only want to perform a filter action on one list and not the others, you can add a data view and use that data view in the filter widget and the list widget you want the filter action to affect. Filter actions on a data view do not affect other data views or the source data.
