Simplify the URL parameters for layer visibility in Experience Builder
809
01-13-2025 06:29 AM
Status: Open
Labels (2)
SarahNoakes1
I would like to be able to create a URL that will open my experience with specific layers switched on.
This page describes how to do this: https://doc.arcgis.com/en/experience-builder/latest/build-apps/url-parameters.htm:
However you need to define the visibility for EVERY layer, which quickly becomes verbose, and if you have a large number of layers in the map widget, it's unusable.
Please update this so that you only need to define which map widget - this should be the name used in Experience Builder rather than the behind-the-scenes-id, and the layers that should be visible in the experience.
E.g. https://experience.arcgis.com/experience/EXP_ID/?layer_visibility:map-widget-name,layer1,layer2,layer3
