Request to add the functionality to retain Attribute Expressions from ArcGIS Map Viewer within the Table Widget in ArcGIS Experience Builder
736
11-04-2025 08:36 AM
Status: Open
Labels (3)
AuroraB
In Web Map Viewer, users are able to create Attribute Expressions using Arcade. When a Web Map is added to an Experience Builder, these Attribute Expressions are visible in the pop-up, but not in the Table Widget or in the Web Map Viewer table. The ability to see Attribute Expressions in a table was a function of the table in Web App Builder and is an important capability.
Example:
1. Attribute Expressions in Web Map:
2. Attribute Expressions do not display within the table in the Web Map Viewer. There is not an option to turn them on or off in the Field Visibility tab within the table:
3. Attribute Expressions populate in the pop-up of a Web Map added to an Experience Builder:
4. Attribute Expressions do not populate in the Table Widget in Experience Builder, nor are they present in order to turn visibility on or off:
Please add the functionality to view Attribute Expressions in the Table Widget in Experience Builder. This an important component in the transition of applications from Web App Builder to Experience Builder.
4 Comments
AuroraB
The Defect Number for this enhancement request is ENH-000178144. Please escalate it in MyEsri.
AuroraB
In ArcGIS Online, it is now possible to add arcade expressions to a layer directly in ArcGIS Experience Builder and to use them in the table widget. There is also a function to copy the arcade of a map expression set in the web map into the arcade script window in Experience Builder. However, if the map expression is updated in the web map, the builder must also update the arcade expression manually in the Experience Builder - they are not linked.
Step 1: Add an Arcade Expression to a Layer in the Data Tab of an Experience Builder
add-an-arcade-expression-in-the data-tab-of-esri-arcgis-experience-builder.png
Step 2: Copy a Map Expression From a Web Map Into the Arcade Script for the Arcade Expression
copy-a-map-expression-from-a-web-map-into-arcade-script-for-feature-layer-in-data-tab-of-esri-arcgis-experience-builder.png
Step 3: Add the Newly Added Arcade Expression to the Table Widget
MikeTownshend
This is great news.  Any word on when this functionality will be available in Enterprise?
AuroraB
I do not know at this time. For future enquiries, the defect number is ENH-000178144. It is currently listed as open and under consideration:
