Making the sidebar widget able to collapse properly on different screen sizes
1881
07-12-2024 12:07 AM
Status: Open
MSCESRI
I've encountered issues with the behaviour of the sidebar widget, with it not being able to collapse properly when changing screen size. I think this might stem from the sidebar size only being able to be adjusted on a pixel basis as opposed to the percentage option.
If I were to adjust the whole widget in the 'style' pane to pixel sizing instead of percentage, it does collapse properly however the widget would remain the same size regardless of the device screen you are viewing on (appear large on smaller screens, small on larger screens).
I would like to propose enabling percentage sizing on the size of the side pane, and perhaps having a setting that allows you to automatically completely collapse the widget without playing around with the size values.
I have attached a recording as well of the behaviour of the widget.
3 Comments
JeffreyThompson2
Live View doesn't give a totally accurate representation of what the deployed application will look like. Do you get the same behavior in Preview mode or the published application?
MSCESRI
Hi @JeffreyThompson2
Yeah exact same behaviour in the published application/preview mode. I adjusted the screen size there using inspect element (Chrome).
NBC
Agreed - this would a very useful improvement.
Being able to control the sidebar sizing would be great for use cases where you need both sides to be a specific ratio size to one another, for example 50:50 for optional side by side map comparisons.
