ExB should recognize identical maps/schemas
2252
6
03-06-2024 07:00 AM
Status: Open
ZachBodenner
MVP Regular Contributor
This is kind of a big request so I'll do my best to explain: If I have an experience that I've spent a good long while configuring, such as data actions, layouts of tables, etc. I'm always a little reluctant to make changes to anything in the map(s) that drive the experience functionality. For example, if I have an experience and a user requests some changes to an application that involve the actual layers in a map, it's really difficult to produce a new experience for them to test - if I make a duplicate web map with the adjustments requested, and then swap that map into the already existing experience, every single configuration breaks, even if the data sources have the same schema, layer indexes, etc. It would be great if I couple copy an experience, adjust a web map slightly and not have to essentially redo everything but the styling.
6 Comments
ThomasRickett
It would be nice to not have to rebuild the experience each time a layer adds a column.
ZachBodenner
Yes @ThomasRickett , perfect use-case example!
JoelBrodeur
That would be great.  To extend on that, I would love to have it so you save an experience as a "template", the template would remove all data sources and then when I create a new Experience from that template, it asks for the data source and rebuilds all my data views etc.
NedCake1
Yes! Would love to see that.
DanMakridakis
The problem is that Esri has not exposed the editor version's JSON to ArcGIS Online Assistant which would allow someone to update data sources and layer IDs for existing apps. They have only exposed the published JSON that is only used by the published app, but never seen by the editor. If you updated the data sources in the JSON for this, anyone looking at the published version would see it. But the second you re-publish from the editor, it would revert back to the old data source.
Check out my idea below for creating multiple draft versions for the same app, it addresses this issue by allowing the editor to see the published JSON and create a new draft version from it:
https://community.esri.com/t5/arcgis-experience-builder-ideas/multiple-draft-versions-for-one-exb-pr...
ZachBodenner
@DanMakridakis  I will kudos that idea for sure, though I think the proposed changes there are relevant to the built in Experience Builder. I use the developer edition, so creating different versions isn't necessarily a huge deal, only, of course, when data gets swapped in an out.
