Enable time-slider linkage between a standalone table and geometry layers in Experience Builder
191
a week ago
Status: Open
Vegove
Description:
Hello,
I’d like to propose an enhancement to the time-slider and data-action capabilities in Experience Builder. In many realistic workflows, users maintain a non-spatial table containing time-series or event data — and a separate feature (geometry) layer containing spatial objects, linked by a shared unique key (e.g. station_id, object_id).
Currently, time-aware tables can be used with the Time Slider — and geometry layers can be filtered via actions — but there is no reliable way to bind them together, so that moving the time slider filters the geometry layer based on the related table’s time-filtered records.
In other words: the desired behavior is that the map should show (or highlight) only those geometries whose corresponding records in the time-aware table fall within the selected time range. This is a common requirement in, e.g., sensor time series, asset-logging, status history, or temporal event visualization — and seems conceptually simple.
Use case example:
  • I have a table of traffic sensor readings (timestamped, non-spatial), and a layer of sensor locations.
  • When I move the time-slider, I want the map to show only the sensor locations for which there exist readings in that time window.
  • I do not want to duplicate or “stack” geometry layers; I want a single geometry layer filtered dynamically based on related table data.
Why this is important:
  • Maintains data normalization: spatial data and time-series data remain separate.
  • Avoids data duplication and stacking of layers (which can cause rendering and maintenance issues).
  • Mirrors realistic GIS workflows (e.g. sensor networks, time series, events).
  • Reduces need for custom coding / developer-edition — makes it accessible to more users.
Proposed enhancement:
  • Allow the Time Slider when bound to a non-spatial table to emit a “time extent changed” event that can drive data actions (filter, highlight, etc.) on geometry layers — potentially via a “related table → geometry layer” binding that matches keys.
  • In the “Filter data records” action configuration, support a linking condition across data sources (table → layer) via key matching.
Thank you for considering this enhancement. I believe it would greatly improve the power and usability of Experience Builder for temporal-spatial data workflows.
Regards,
A user of ArcGIS Online / Experience Builder
1 Comment
EndreLeivestad
Splendid idea!
