Draw widget improvements
189
03-27-2025 05:27 AM
Status: Open
Labels (2)
ClintOffutt
It would be nice if there was an option to change units on the Tooltips of the Draw widget.  I work with cadastral data in the US and feet is the preferred unit.  If I try and change the coordinate system, inaccuracies in the measurements/labels occurs.  Please make it so we can choose which unit is desired.  Here is a simple example of the problems encountered when using a different coordinate system that uses feet as the unit:
Same thing happens with linear measurements.
thank you!
