Batch Attribute Editor in Experience Builder
21045
38
08-27-2024 10:05 AM
Status: Implemented
Labels (2)
emontague_napsg
Real-world Problem: First responders are working on an Urban Search & Rescue team during a tornado or flooding event. To organize their search operations, they use a Web AppBuilder product called Intel Manager within SAR Common Operating Platform (SARCOP) to quickly create search segments and monitor what has been searched. By using the Batch Attribute Editor widget within Web AppBuilder, first responders can quickly select numerous points that they previously assigned as "Needs to be searched" and change this attribute to "Complete - No Follow-Up Needed." This workflow is critical to minimize time spent searching for disaster victims and reduce duplication of effort. Many teams work within the same app. The ability to filter to a specific attribute (e.g., Team Name) while selecting for a batch attribute edit is also significant to reduce mistakes and streamline the workflow.
The screenshot below shows an example incident within SARCOP with about 60 points.
See below, the user can choose to select a group of points by drawing a freehand polygon.
 In the screenshot below, the points in the selection polygon were selected and the user can update attributes for the group of points all at one time.
Audience: First Responders, Urban Search & Rescue Team Members,
Technical Problem: Batch Attribute Editor widget is not available within Experience Builder. We are migrating these apps from Web AppBuilder to Experience Builder in anticipation of the deprecation.
Potential Solution: Ability to edit attributes using a batch selection within Experience Builder, similar to Batch Attribute Editor widget from Web AppBuilder. Batch editing attributes without the need to utilize a separate ArcGIS product is important to this workflow because our users are often working in time sensitive environment on a tablet or mobile and might not have any prior GIS experience outside of our app SARCOP.
38 Comments
AlixVezina
Batch editing is currently under development in the ArcGIS Maps SDK for JavaScript. Once available in the SDK, the functionality will be brough into Experience Builder. Right now, this is targeted for 2025R1.
AlixVezina
DataOfficer
@AlixVezina batch editing in Experience Builder was originally scheduled to be available for Q4 2023, and then Q4 2024 according to Esri's documentation and timetable. Are you now saying that this is being further extended to Q1 2025?
ScottStepro1
Ironically today is my monthly checkin on batch editing… have been asking for this since EB was released. Good thing no one is holding their breath… quite the runaround for something that on the surface seems so simple.
Slow down developing new apps and instead improve what’s already available; why even release EB without batch editing?
AlixVezina
@DataOfficer @ScottStepro1 I totally understand and sympathize with the frustration, and we sincerely apologize for the delay and any inconvenience this may be causing you.
There is a plan for the Web Editor to be the first app to expose batch editing in 2024R3. See Batch Attribute Editor - Esri Community for updates.
AlixVezina
See update from the Web Editor team: What's New in ArcGIS Web Editor (November 2024)
Batch editing is now planned for the first release of 2025. The plan is also to provide it through other apps (e.g., Experience Builder) at the same time.
JasonJordan00
Glad its moving forward but compared to the current batch attribute tool that looks clunky and unintuitive for most users. I feel like having the option to still update a single feature with many selected is going to lead to a lot of user error.
Will there be an option have multiple instances of this widget? For instance, right now for an emergency management application we rotate in a lot of volunteers that are unfamiliar with GIS. To help with their job we have a WAB that has several batch attribute widgets, each configured to only select certain features and have different attributes they can update. Each is labeled 'Click here to assign a field assessor', 'Click here to assign a contractor', etc.  Will this be able to support a workflow like that?
ScottStepro1
@AlixVezina My apologies but I am a bit confused... Will this allow us batch edit multiple features simultaneously or only batch select and edit individually?
AlixVezina
@ScottStepro1 @JasonJordan00
You'll be able to do both, edit features individually or all the features at once.
ScottStepro1
@AlixVezina that's great news, thank you.  Look forward to its release
