I have been desperately waiting for the configuration option to allow for an input auto select in the "Near Me" widget. The current workflow is that before a user can utilize the Near Me widget they have to click on a tiny little map pin in the tool (even though it is already active) and then click on the map. This is not very intuitive for most users and I had to put very unsightly language in the app to tell them to click on the pin first which most still ignore. I would love if there was a configuration options where once the widget was active it would auto select the map pin (this was standard in Geocortex) so the user could just click on the map for their information. I understand this wouldn't work for varied inputs like if you had points, lines, and polygons but it should work if the user only has one option like points in my case. I've been waiting for this option since the beta of this tool and it seems like a simple configuration option but it doesn't seem like it will ever come.
Maybe it's not exactly what you want for your application, but it is possible to build an application like yours that is auto-triggered by a mouse click.
