Check out a sneak peek of upcoming new features in Experience Builder in ArcGIS Online June release. More capabilities are migrated from Web AppBuilder to Experience Builder. In addition, you can use Google Analytics to track the app usage.
@Jianxia Regarding custom URL parameters, are you confirming that we will be able to use the data select parameter (data_s) to not only highlight the feature, but also pan and zoom to its extents? When should we be expecting this June update (if it has not already released)?
@WilliamBarker2, by default, the select data url parameter pans to the feature. In the June release, you will be able to zoom to the feature with a new zoom_to_selection parameter. However, this new parameter only works when you select a single feature by ID. We will enhance it ito work with the rest of selection scenarios in the Q4 release.
I second @KaraUtter2 message. URL parameters are way harder in ExB than WAB and there's almost no useful help or resources. I can't do what I need to do and was able to do in Wab and it's quite frustrating! Zoom to a set of coordinates via url parameters should be simple!!!!
Feature selection for the feature info widget is no longer centered. I couldn't find any information about this change with the update notes and am looking for a way to revert it. Any suggestions or similar experiences?
@Jianxia I am trying to use URL parameters to zoom to selected feature in Experience which was supposed to be in June release. I am being told by support that "we do not have the functionality to zoom in using URL parameters. Even the enhancement status is still under consideration." Can you clarify whether this update has been made and, if so, how do you write the URL?
@WilliamBarker2 and @GrantWilcox, thanks for figuring it out. Here is a sample app with zoom to feature url parameter. We just informed Support about this parameter. Will update the Use URL parameters document.
There are 4 cases for selection. Only the first case is supported with the new zoom_to_selection=true parameter. We will add the rest of them in the next release. Thanks for being patient with us.
can you please view my video below, and let me know if the reason I am required to enter the address twice in the Get Directions option of the Near Me widget is a known issue? - Thank you.
here’s a screenshot ($h*t Rental Radar) showing Feature Selection for the Feature Info widget now left-aligned, whereas it was previously centered. The Title element has also become left-aligned. I was able to center the title (address) by moving it into Content, but there are no options available to adjust the position of Feature Selection.
Any ideas or is this something I could bring up with customer support?
You are using query widget in your app. Near Me supports direction when direction widget is configured in the app and you have point data. The action is called Route, you don't need to enter your address twice if you get direction from Near Me.
@AlbrechtDylan, thanks for sharing. The left-aligned feature navigation is by design. In this release, Feature Info widget is refactored to display features from multiple layers. Given the need for the layer navigation on the right, the feature navigation is now left-aligned as shown below.
