webgisdr - Export Failure: Configuration store error (Non Default 'Local Repository Path')
7345
10
06-25-2019 12:07 PM
pfoppe
by MVP Alum
We are trying to execute the webgisdr utility on one of our ArcGIS Enterprise solutions. The ArcGIS Server 'Local Repository Path' is not the standard C:\arcgisserver\local\config-store but instead placed on a 😧 location. Here is a quick snip from the ArcGIS Server admin console:
And the failure we are getting from the webgisdr utility:
C:\Program Files\ArcGIS\Portal\tools\webgisdr>webgisdr.bat --export --file D:\we
bgisdr\webgisdr.properties
Starting the WebGIS DR utility.
The configuration and base backup time in the current Web GIS
Portal: https://www.example.com/portal
|-- Hosting Server: https://MachineName.Domain:6443/arcgis
| |-- Relational Data Store: https://MachineName.Domain:2443/arcgis
Starting the backup process with the WebGIS DR utility.
Starting the backup for Portal for ArcGIS:
Url: https://www.example.com/portal.
Starting the backup for ArcGIS Server:
Url: https://MachineName.Domain:6443/arcgis.
Starting the backup for ArcGIS Data Store:
Url: https://MachineName.Domain:2443/arcgis.
Failed to back up the ArcGIS Server:
{"code":500,"messages":["Export operation failed. Configuration store error. File system 'C:\\arcgisserver\\local\\config-store' connection failed. The specified location is not accessible. Ensure that the ArcGIS Server account has read and write access to the location. "],"status":"error"}
The following ArcGIS Data Store has been backed up successfully:
The backup of ArcGIS Data Store has completed in 00hr:00min:21sec.
The following Portal for ArcGIS has been backed up successfully:
The backup of Portal for ArcGIS has completed in 00hr:07min:37sec.
The backup of Web GIS components has completed in 00hr:07min:56sec.
Stopping the WebGIS DR utility.
It seems the WebGIS DR utility has a hard coded built in reference to the C:\ path  Any suggestions for resolution?  Thanks!
Tags (1)
Natalie_Runyan
Thank you Jonathan. I was able to get webgisdr to work. I suspect the online instructions have been updated since I last used them, which clarified the use of the FQDN. Thank you for the great explanations and offer of help.
