Webapp URL parameters (error with Chrome, works in firefox)
925
02-28-2022 10:07 AM
RyanBohan
The feature layer has many points with the same Artist name, and different dates.  I want a single link for the artist, and the map automatically takes you to the current location depending on the current date.
I am trying to use URL parameters along with a filter on a Webapp.  ...&find=Test%20Artist
https://webmaps.sandiego.gov/portal/apps/webappviewer/index.html?id=e05946e66cf24272af5dd779195317ff...
In firefox it works great.   The find results are filtered and the correct location is returned, tomorrow it will zoom to a different location.
In Chrome the filter is ignored when using the URL parameters, so the map zooms to the wrong location.  How do I get chrome to behave the same as firefox?  If you do a search in the search widget the correct location shows up.
Any thoughts how how to fix this?  Thank you
