Configuring a reverse proxy with ArcGIS Enterprise: same url for Portal and Server supported?
3034
02-27-2022 12:55 PM
Jay_Gregory
I have inherited an ArcGIS Enterprise 10.9 instance - it has been configured with a reverse proxy instead of ArcGIS WebAdaptor.  Both the Portal AND Server have been placed under the same URL - https://arcgis.mydomain.com/arcgis.
So for example going to Portal homepage is https://arcgis.mydomain.com/arcgis/home and going to Server REST endpoint is https://arcgis.mydomain.com/arcgis/rest/services.
I know this URL structure (using the same context for Portal and Server) is not supported using WebAdaptor, but I have not been able to figure out if its supported with a reverse proxy.  I have poked around a little and haven't noticed any big issues and nothing seems broken but the site isn't heavily utilized yet either.
My questions are:
1. Is this setup valid / supported?
2. If not, what potential issues can it cause.  i.e. where can I look for and validate problems.
3. If so, what other Enterprise related configurations are necessary - WebContextURL settings and the like?
Thx
Scott_Tansley
MVP Regular Contributor
have you had a good read of this:
Integrate your portal with a reverse proxy or load balancer—Portal for ArcGIS | Documentation for Ar...
and
Configure a reverse proxy server with ArcGIS Server—ArcGIS Server | Documentation for ArcGIS Enterpr...
The rules seem to depend on which Reverse Proxy you're using and it's capability.  You haven't mentioned which proxy so it's hard to be a bit more specific.  If this was a manual build of Enterprise, rather than from a builder, then I'd consider trying to push Web Adaptors in if you haven't created content.  It's a cleaner build and eminently more supportable (simple) in my opinion.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
Jay_Gregory
Thanks - I had read through but since I'm not a load balancer expert I might have not read as thoroughly 🙂
So the only mention I could find is in the Portal section:
"When not using the ArcGIS Web Adaptor, the default context (/arcgis) must be used for the site. When integrating multiple Portal for ArcGIS and ArcGIS Server sites on the same layer 3/4 load balancer, a unique DNS record should be used for each site and Server Name Identification (SNI) used to route traffic to the appropriate back-end targets."
So what I can take away from this is if we're using a layer 7 load balancer, using the same context is supported - it is not supported with a layer 3/4 load balancer.  Still don't quite understand the implications but good to know.  Wish this was stated more explicitly somewhere, and cross referenced in the Server section as well.
I agree with WebAdaptor - I'm am much more comfortable in that environment, especially with HA or multi-node sites.  Unfortunately at this point it is out of my control somewhat - we're using AWS and I think a ALB is easier for IT to maintain than Apache w/ 3rd part (i.e. esri) app installed.
