Using X,Y Coordinates when Uploading CSV File
2891
02-09-2021 03:33 PM
cardiofaz
Hi all,
When uploading a CSV file, i have to keep it to a LONG, LAT standard. Any ideas on how i can change this to X,Y?
So when a user uploads a csv file, it picks up the X and Y coordinates? At the moment, it comes back empty but works with LAT and LONG.
https://doc.arcgis.com/en/arcgis-online/reference/csv-gpx.htm
Tags (1)
AlisonKelsey
Hi @cardiofaz,
I've used this in both ArcGIS Map and ArcGIS Pro.  In AGOL, you can choose to add a new item (the table containing your latitude and longitude) from your computer, and check the checkbox to publish the file as a hosted web layer.  In this dialogue box, you select the radio button to add the features by coordinates (see image below)
Cheers,
Alison
Cheers,
Alison
AlisonKelsey
Hi @cardiofaz,
In the contents window, right-click on the table containing the X,Y data.
From the pop-up menu, Select Display X, Y data.
The Dialogue box will allow you to select the fields for latitude and longitude.
Alison
cardiofaz
@AlisonKelseyThanks for this, i am struggling to find this. Are you checking in   ArcGIS enterprise?
AlisonKelsey
Hi @cardiofaz,
Cheers,
Alison
Cheers,
Alison
