Upload PNG image using /addItem
1503
08-17-2023 02:41 PM
julian_svcs
I am trying to upload a PNG file as an item to Portal using /addItem using python post calls.
What format should 'file' be? I have tried converting to a binary image (a whole series of 0's and 1's) and also tried the file path. The item is created but it is "empty".
When I do this manually and look at the dev tools for the '/addItem' post, it is set as 'file: (binary)'. I am not sure how to create the '(binary)' file type using python.
Any help and code examples for this will be great, thanks very much.
Regards, Julian
David_McRitchie
Hey Jilian,
Based on the documentation I believe a file path should suffice. Hopefully some of the examples within this help.
Many thanks,
David
Esri UK -Technical Support Analyst
julian_svcs
Hi Divid. That doesn't work. I tried the path to the file and also tried to convert the image to binary and use that. In both cases it creates the item but it is empty.
I had a look at that website you posted but I don't see where it specifies the file path for 'file' or see anything in the examples.
Here is my json for the data post request:
logo_title = "Logo.png"
logo_path = r"c:\_scripts_\_scratch\{}".format(logo_title)
data_add_item = {
    "title": f"Shared Theme Logo - {os.path.splitext(logo_title)[0]}",
    "description": "This image was uploaded for use as your organization's shared theme logo.",
    "type": "Image",
    "tags": "SharedTheme, Logo",
    "f": "json",
    "file": logo_path,
    "token": token
freddies
The 'file' parameter is of binary. Anyone know of a way to specify the value/content of this 'file' parameter?
