Upgrading ArcGIS Server step 2 of 2: Failed. Synchronize with site
1737
7
08-12-2024 07:21 AM
Sakib_Meharan_Siddiquei
Hi all,
Hope you are doing great.
I am trying to upgrade ArcGIS Enterprise from version 10.9.1 to 11.3, on a multi-machine environment on Linux, Ubuntu 20.4.
I have successfully performed the Portal upgrade, and the Portal Web Adaptor.
And I also ran the ArcGIS Server Setup, which was also successful, the problem I am experiencing is in the post-Upgrade phase of ArcGIS Server, with the command ./upgradeserver.sh -s, and this is the error:  Upgrading ArcGIS Server step 2 of 2: Failed. Synchronize with site.
I have checked the permissions on all the folders, and I cannot go and alter the security-config.json file, as it is federated with Portal.
I thought the ArcGIS Server keystore got corrupted, but on the catalina logs I find only this:
WARNING: The web application [arcgis#admin] appears to have started a thread named [GPJobExecutorSingletonExecutorThread] but has failed to stop it. This is very likely to create a memory leak. Stack trace of thread:
java.base@17.0.10/jdk.internal.misc.Unsafe.park(Native Method)
java.base@17.0.10/java.util.concurrent.locks.LockSupport.parkNanos(Unknown Source)
java.base@17.0.10/java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(Unknown Source)
java.base@17.0.10/java.util.concurrent.LinkedBlockingQueue.poll(Unknown Source)
com.esri.arcgis.discovery.admin.rediscovery.GPJobExecutorSingleton$ExecutorThread.run(GPJobExecutorSingleton.java:554)
And on the Server logs:
"SEVERE" code="7185" source="Admin" process="778379" thread="1" methodName="" machine="//" user="" elapsed="0.0" requestID="96f03588-26f1-4143-9a05-dae52748442e">Failed to synchronize machine '//' with the site. Cannot invoke "com.esri.arcgis.discovery.admin.services.Service.getProvider()" because "<local11>" is null. You can attempt the synchronization again by using the synchronize Administrative REST API on the server machine resource.
Has anyone by chance ever experienced this problem?
I would be very grateful if you can provide me with a hint to fix this issue.
Thanks & Regards,
Sakib
ChiefKeefSosa300
Hi Sakib, I also encountered the same problem with you. I try to upgrade arcgis server 11.2 to 11.3 and suddenly Upgrading ArcGIS Server step 2 of 2: Failed. Synchronize with site in browser. I already send an email regarding this problem. Have you solved it yet?
FarrukhZahid
Hi Chief. Any update on your email? Did you find any solution for this? I am facing the same issue on windows platform 11.0 to 11.4 "Upgrading ArcGIS Server step 2 of 2: Failed. Synchronize with site"
ChapalChoudhury
Hi all,
I have also encountered the exact same issue while trying to upgrade from version 10.9.1 to 11.4 by running both silently and with the upgrade wizard.
Looks like the first 3 stages of the server upgrade process was successful but failed at the 4th stage and did not proceed with the remaining 3 stages (see the attached screenshot).
  • Initialize upgrade and check licenses - Succeeded
  • Upgrade site configurations - Succeeded
  • Upgrade and start System Utility services - Succeeded
  • Synchronize local machine with site - Failed
  • Configure Extensions and data providers – Not started
  • Generate SSL Certificate and Enable SSL– Not started
  • Final checks and cleanup– Not started
Has anyone got a solution to the issue?
Jay_Geisen
I'm curious how (any of) you sorted this issue out? We're running into similar errors, post 11.5 upgrade.
MikaelJ
@Sakib_Meharan_Siddiquei  @Jay_Geisen
any updates on this issue? I am facing this for couple of machines when upgrading to 11.5 from 11.3
Jay_Geisen
We fixed the issue we were having by re-running the License Authorization file for all three of our GIS Server machines. Not sure why this worked, but it seemed to do the trick.
MikaelJ
Oh, kinda interesting.
For me, solution was upgrade of Edge or Chrome.
