Updating ArcGIS enterprise to11.3
1147
11-22-2024 08:17 AM
GSala
I was updating ArcGIS Enterprise from version 10.6 to 11.3. I successfully updated ArcGIS Server and installed ArcGIS Portal and ArcGIS Datastore, setting up the server site and the portal site correctly. However, after a few days, I checked the server and noticed that the Portal service was not running. When I tried to restart it, I encountered the issue shown in the attached photos.
RickeyFight
MVP Regular Contributor
@GSala  If possible have you reached out to tech support?
GSala
I'll Try that as well. I was hoping that someone in the community had already encountered this issue
RyanUthoff
I'm assuming you upgraded directly to 11.3 from 10.6? If so, that is not supported. This could be what is causing you issues. You'll need to upgrade to a lower version first, then upgrade to 11.3.
Upgrade ArcGIS Enterprise—ArcGIS Enterprise | Documentation for ArcGIS Enterprise
GSala
Yeah, sorry, I forgot to mention it. I didn’t upgrade directly from 10.6 to 11.3 but went through version 10.9 first.
simoxu
by MVP Regular Contributor
Check the portal for ArcGIS account permissions:
At a minimum, this account must be granted the following privileges:
  • \arcgis\portal*—Read, write, and execute
  • \arcgisportal—Full control
Please see details using the following link:
https://enterprise.arcgis.com/en/portal/11.3/administer/windows/the-portal-for-arcgis-account.htm
