Undo Join Feature in Map Viewer
2266
02-24-2023 10:41 AM
by Anonymous User
Not applicable
Hello,
I would like to add a field in my feature layer.  However,  this is not possible because I have used the feature layer in map viewer and created a join. The image below is how I created the join in map viewer.  I need to know how to undo the join. Simply removing the join does not allow me to add a field. Does anyone know the steps to undo a join? @ChrisDelaney   Thank you very much, Annette
Michael_Kraus
Join Features will create a new layer with the results of the join.  It isn't an in-memory join like in desktop ArcGIS applications, so there is no real undoing of the join - other than deleting the resultant layer.
To add a field to your feature layer, look in the Contents at the item details page - Data - Fields - Add Field
by Anonymous User
Not applicable
Hello,
Yes you are right, I meant to say creating a join view.  With a join view, unfortunately you cannot add fields. See images.  When the layer is a join view, that's when you have to undo it.  The add, plus sign, in the Critical Infrastructure Data and Survey is missing because I used this layer in a join view.
I did receive instructions on how to undo the join view.  Here it is in the blog - https://doc.arcgis.com/en/arcgis-solutions/latest/reference/configure-police-transparency.htm#ESRI_S....
Thank you,
Annette
