Unable to publish Routing Service utilizing "Publish Routing Service" tool from ArcGIS Server
1152
06-05-2023 11:49 PM
ArchitSrivastava
Hello All,
We have a ArcGIS Enterprise High Availability 10.9.1 environment with the following configuration:
  • ArcGIS Portal : Two machine
  • ArcGIS Server : Two Machine
  • ArcGIS DataStore : Two Machines
  • Third Party Load Balancer : Assists in Load balancing
We are trying to utilize "Publish Routing Services utility" which is in-built ArcGIS Server. However, it keeps failing for us with the following error in "publishroutingservices.log" file:
v = self.send(byte_view[count:])
File "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\bin\Python\envs\arcgispro-py3\lib\ssl.py", line 1003, in send
return self._sslobj.write(data)
OverflowError: string longer than 2147483647 bytes
However, we have checked the capability of "Publishing Tool" and all other services involved and made sure that they allow uploads lager than this.
As this is in-built utility, we expect that the internal process take care of themselves.
Any help would be appreciated!
@JonathanQuinn @George_Thompson
ArchitSrivastava
We were able to resolve this issue by creating a copy of the data on both all machines participating in ArcGIS Server Site. Once we did that, the size of service definition files decreased substantially
Then we made minor changes to the script as per our required (Not recommended to do this, try above first )
and fixed the overflow error.
This approach we took based on the documentation:
https://enterprise.arcgis.com/en/server/10.9.1/develop/windows/publishing-routing-services.htm#ESRI_...
Posting this as it might be of help to anyone in future.
Hope it helps!
ArchitSrivastava
Hope it helps!
