Portal for ArcGIS 11.1 - Configure SAML Authentication - Import x.509 string from Metadata URL fails
755
07-11-2023 02:13 AM
MaxBöcke
Hi community
I've imported the IdP Metadata via URL and saved the configuration. Subsequently, I had a meeting with our IT IdP responsible person, who registrated the Portal (SP) at IdP.
The login test fails then. After comparing the entries between IdP-Metadata and the entries in the Portal, I figured out that the Certificate was imported wrongly. The string has been cutted. After replacing the whole string, everything works fine.
This is not a question! Help me, if this Post is placed wrong.
Cheers,
Max
