SQL Server in place update 2016 ->2022
5245
10
06-02-2025 08:00 AM
GIS412
Our org has updated to arcgis pro 3.3 and enterprise 11.3. We are also on sql server 2016 sp2. I recently discovered that sql server 2016 is not supported..
Has anyone done in-place upgrade? Since upgrading to sql server 2016 sp2-> sql server 2022 requires us to patch to sp3. I guess we could snapshot the machine in it's current state then patch to 2016 sp3. Once patched to sql server 2016 sp3, test the services and stability. If all are good, then snapshot again and upgrade to 2022. This seems like the best option as we wouldn't have to re-register data and point all our projects and layers to a different data source.
Has anyone been in this situation? Did it work out fine?
GIS412
Thank you for all your responses!
