Sign-In to Portal Via Python Script Creates SSL Error for Service Account
3769
5
12-23-2024 08:32 AM
McKinneyPatrick_PA
We recently updated the SSL certificate for our single-machine base deployment of ArcGIS Enterprise 11.1.  With my organizational user account, I can sign-in and access the Portal via a Python script from both my laptop, and logged onto the server.
However, whenever I am logged onto the Windows server with a service account (headless user), I get the following error when signing-in to the Portal.  Note, the same script is run.  The only difference is whom is logged into the server.
Does anyone have any ideas what might be causing this issue?
2024-12-16 18:00:22,869 - signing into Portal…
2024-12-16 18:00:25,237 - Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)'))': /portal/sharing/rest/info?f=json
2024-12-16 18:00:31,236 - Failed at Line 40
2024-12-16 18:00:31,236 - Error: Please set verify_cert=False due to encountered SSL error: HTTPSConnectionPool(host='gis.health.pa.gov', port=443): Max retries exceeded with url: /portal/sharing/rest/info?f=json (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1129)')))
A_Wyn_Jones
Python has it's own certificate store which doesn't include your certificate by default. For best practice, you should add this certificate to the python store to ensure your python environment trusts your Portal Url.
You can do this using certifi, ssl and requests modules.
You can ignore these warnings within the python session with:
import ssl
ssl._create_default_https_context = ssl._create_unverified_context()
It's less secure to ignore the warnings but will suppress these warnings for you.
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
JoshuaBixby
MVP Esteemed Contributor
It is true Python can be compiled to use its own certificate store, and it is true some packages like certifi do include their own certificate store by default, but Python made a decision over a decade ago to default to the system or host certificate store.
From PEP 476 – Enabling certificate verification by default for stdlib http clients | peps.python.org (which was accepted and applied to 3.4+ and 2.7.X+)
Trust database
This PEP proposes using the system-provided certificate database. Previous discussions have suggested bundling Mozilla’s certificate database and using that by default. This was decided against for several reasons...
Esri does not override Python's default for ssl, at least on Windows systems (I assume the same on Linux but haven't confirmed myself).  It may be possible the function the OP is calling does rely on a package containing its own certificate store, but without more specifics from the OP no one can say one way or the other.
A_Wyn_Jones
@JoshuaBixby @McKinneyPatrick_PA
Apologies Josh, yes I should've specified that this is necessary whilst using a cloned conda environment (via arcgispro-py3) and whilst making use of python libraries within that conda environment e.g. requests.
I've come across this recently whilst using a cloned conda environment and using verify=True when querying a job URL via requests:
response = requests.post(
                        status_url,
                        params={'f': 'json', 'token': token},
                        verify=True
(Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1006)')))
SRK
I am behind a coporate firewall and it seems arcgis-python3 does not has the locally installed certificate from windows, as i can call a webadress in multiple browsers but not in python. I am using the default arcgis-python3 enviroment, but due to that i can't add custom certs in the certifi cert bundle as the directory is writeprotected...
How can i update cerifi to include sytem certs oder check if they are used?
Edit: I found this post which is almost 4 years old and the solution really should not be manually changing the .pem cert bundle... Is there really no update function to check for the current windows certs??
FredericPoliart_EsriAU
Today, for some strange reaon, I started receiving this same error[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: unable to get local issuer certificate (_ssl.c:1006)'))
on a python script that I use pretty much every day.
How I fixed it:
add:
   urllib3.disable_warnings(urllib3.exceptions.InsecureRequestWarning)
add verify_cert=False on this line:
   gis = GIS(source_portal_url, token = mytoken, verify_cert=False)
add verify=False on this line:
   requests.get(url, params={"token": token}, verify=False)
.. then it works again to fetch a Portal URL to an image (purpose of the python script in my case)
WHY TODAY!?!?!
> Could is be SSL CERT validation becomes expired?
