Some internal URLs redirect to public URL
304
02-26-2025 09:02 AM
CarstenHogertz
Hello everyone,
I am running ArcGIS Enterprise 10.9.1.
I think it seems to be misconfigured somewhere. I notice a strange behavior regarding redirects.
The server and the portal have a public URL. However, some work also needs to be done in the backend and I keep running into a problem with the different endpoints:
If I call up the following URLs, the redirects URL always remain with the backend URLs:
https://<FQDN>:7443/arcgis/home/
https://<FQDN>:7443/arcgis/portaladmin/
https://<FQDN>:7443/arcgis/sharing/rest
https://<FQDN>:6443/arcgis/admin/login
-> never a redirect to the public URL. Important: even the portal login screen in this cases is called up with the backend URL. Everything is great!
What I don't understand is the behavior with the following URLs:
https://<FQDN>:6443/arcgis/rest/services/
If I open publicly available services, the backend URL remains. However, if I open a secured service, the login screen is called via the public URL.
https://<FQDN>:6443/arcgis/manager/
Here, I am redirected to the public URL of the portal login screen immediately after opening it.
Is this normal behavior? Is something configured incorrectly in the AGS? If I call up the login screen via 7443, the backend URL is also used. Why when coming from 6443 I am redirected to the publich URL?
The whole thing is problematic in the sense that the backend cannot call up a URL from the public web.
Many thanks for your help!
DavidCrosby
Have you set the webcontexturl in the Portal?  This post might be helpful to understand how it works.
