Understanding Impact of removal of Python 2.x from ArcGIS server 10.9.1
310
02-18-2025 09:10 AM
SaurabhDudhe
We understood that :
(a) 'ArcMap Runtime' uses Python 2.x within 'ArcGIS Server 10.9.1'.
(b) We also understand there is a way to disable 'ArcMap Runtime' as per - https://enterprise.arcgis.com/en/server/10.9.1/administer/linux/disable-arcmap-runtime.htm
- we are using 'ArcGIS Maps SDK' to consume features from 'ArcGIS Server 10.9.1'.
- We are using 'ArcMap' to publish layer services into 'ArcGIS Server 10.9.1.
We have below queries :
(1)  Will it impact us if we disable 'ArcMap Runtime' as per (b) while consuming already existing/configured services/layers in 'ArcGIS Server 10.9.1' using 'ArcGIS Maps SDK' from our web application ?
(2) In this setup, can I just replace 'ArcMap' with 'ArcGIS Pro' to publish services/layers into 'ArcGIS Server 10.9.1' after disabling 'ArcMap Runtime' as per (b)  ?
Our need is -
We want to continue using 'ArcGIS Server 10.9.1' for its services from client App (using 'ArcGIS Map SDK'), after disabling 'ArcMap runtime' in the server. This is just to ensure 'Python 2.x' is not present and things are still working after layers are published.
Thanks in advance.
DavidCrosby
The ArcMap runtime gives you the ability to publish services using ArcMap - when you do, they will use the ArcMap runtime.  When you publish the service using ArcGIS Pro, it will use the ArcGIS Pro runtime.  Have you already migrated your services to the Pro runtime?
