Sever Level Logs in ArcGIS for Server (Exception Messages)
23155
35
12-23-2021 11:00 AM
TimHayes2021
 I was looking at the Debug Logs in our ArcGIS Server Manager and see two Severe Level Logs:
Exception in Put(): 4672 Put exception: the client id
4672 already has a value
GIS_Housing.MapServer_4673 checked out.
Housing.MapServer
Exception in Get(): _GetItemIterator exception: client id
4672 is trying to check out GIS_Planning.MapServer
but it already checked out
Housing.MapServer4672
Housing.MapServer
These services are both sourced from our Enterprise GDB (SQL Server not a File GDB or Data Store).
Any thoughts on what these message mean and how to resolve them?
nacelle_pylon
Having the same issue as all the others noted. Looking into @AmandaDeMedeiros link to it being associated with BUG-000147815
My issue seems right on line with what @Joel_Lopez noted. Joel, any resolution?
Joel_Lopez
Hi there, sorry for the late reply. I had a call with esri technical support about this about a year and half ago. They just summed it up to a bug. And because it doesn't seem to actually affect the services themselves, no action was taken. We did try to recreate the DynamicMappingHost.MapServer service, but that didn't solve anything. If I remember correctly, that DynamicMappingHost map service plays a part in the managing shared instances.
MichaelVolz
Esteemed Contributor
Server logs identify this issue as SEVERE, but ESRI tech support says that it has no impact on AGS services.  If that is the case as per ESRI tech support, why report this error as SEVERE (Just make it a warning)?
JimCarmichael1
Same issue....11.2
santa_g
Any updates? Same issue in 10.9.1
LaurensKusse_hhdelfland
Issue also exists in 11.3.
arahman_mdmajid
So we are facing the same issue and the service is both Map and Feature enabled. We are using Enterprise version 10.9.1. This particular layer is sometimes working and sometimes not while add the service in ArcGIS Pro (v3.3.2) via catalog.
Abdur Rahman
GIS Developer
GinoMellino
FWIW we had a bunch of these errors going on today with our production site at Enterprise 11.3. They all seemed to be associated with System/DynamicMappingHost; stop/starting System/DynamicMappingHost in the admin endpoint seemed to resolve the issue. Hope it helps.
JenniferDooley1
Add us to the list of orgs affected by this bug.  Upgraded from 10.9.1 to 11.3 and have been getting the DynamicMappingHost crashes since day one of 11.3.  Just got off the phone with support, and they suggested what @GinoMellino mentioned above.  We're also going to move as many services from Shared to Dedicated instances as is practical.  We've been getting significant latency during periods of only moderate use as a result of this issue. Our fingers are crossed that this gets addressed at some point so we can avoid workarounds.
JessicaJackson
Worked with support and found that I could access the rest endpoint since the DynamicMappingHost service was not available in Server Manager.
https://<<your site>>/webadaptorforservername/admin/services/System/DynamicMappingHost.MapServer
The Maximum and Minimum Instances per Machine was set to 60!! I changed it to 4.
