Saving credentials for shared maps in ArcGIS Enterprise to avoid double authentication
1645
03-24-2023 05:29 PM
PlaninforAdmin
I am sharing a map with another organization in ArcGIS Enterprise, and every time they try to access the map, they are prompted to enter their credentials for the server that is sharing the map. Is there a way to save these credentials to avoid double authentication?
ChristopherCounsell
MVP Frequent Contributor
https://enterprise.arcgis.com/en/portal/latest/use/connect-secured-services.htm#GUID-352C33B1-6D15-4...
Add the service as an item, with credentials embedded. Then share the added item / add it to Web Maps (don't add the original service URL).
Also see collaboration for a broader portal-portal sharing workflow:
https://enterprise.arcgis.com/en/portal/latest/administer/windows/understand-collaborations.htm
ChristopherCounsell
PlaninforAdmin
Muchas gracias.
