REST API query returns no geometry for complex polygons
1566
08-21-2020 06:58 PM
KellyChan
Enterprise 10.7.1 query doesn't return any geometry if the polygon is complex (very many vertices.) This occurs when requesting f=pbf. But, of course, featurelayer defaults to pbf these days. How can we fix/work around this
No geometry
Many rings
JoshuaBixby
MVP Esteemed Contributor
Can you elaborate on "very many vertices"?  And, did this work in previous versions of ArcGIS Enterprise?  Also, does it work if you change the output format?
KellyChan
haven't pin point the threshold number of vertices which breaks the query.
yes, work from earlier version
yes, work with f=json/xml
JoshuaBixby
can you share either a polygon that has the issue or create a sample/example that shows the same issue?
