Register Enterprise Geodatabase using python
2473
09-11-2023 02:00 AM
Sfortunatamente
I am having a problem while trying to register enterprise geodatabase using python in ArcGIS Pro 3.1.1, I get the following error message:
RuntimeError: Cannot open AGS server connection.
I use arcpy.AddDataStoreItem method.The file is ok, I connect to a server using it. The server is federated with the Portal. I read somewhere that it was a known bug back there.
I have dozens of geodatabase connections (different users/schemas) and would not like to do it manually.
Any ideas? I did not find geoprocessing tool to do that either.
Thanks, Bart
Tags (1)
Sfortunatamente
you could have been right Marcelo, I had no problems with running the script in ArcMap 10.8.1 python 2.7 env against ArcGIS Enterprise 10.8.1. That's satisfies me for now.
Thanks!
Bart
A_Wyn_Jones
Which version of ArcGIS Enterprise are you attempting this with? The compatibility of the geoprocessing tool may be affecting your workflow: https://pro.arcgis.com/en/pro-app/latest/help/analysis/geoprocessing/share-analysis/geoprocessing-se...
"We've boosted the Anti-Mass Spectrometer to 105 percent. Bit of a gamble, but we need the extra resolution."
Sfortunatamente
I am not sure I understand your answer. I do not publish geoprocessing service (as addressed in the link provided). I want to automate registering enterprise geodatabases using Python ran in ArcGIS Pro 3.1.1 against ArcGIS Enterprise 10.8.1. I have no problems registering gdbs using ArcGIS Pro "Add data store" tool. But python script fails..
MarceloMarques
@Sfortunatamente - suggestion, please open a ticket with Esri Technical Support to investigate the issue further.
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
Sfortunatamente
Thanks!
Bart
